Need help generating XLSX file through script
chaitanya2948
Hi Team,
I need your help with generating an XLSX Excel file through a script in ServiceNow.
I tried some scripts, but they only work for .xls format, not for .xlsx.
Do we have any OOB library available (similar to PDF generation) that supports XLSX file creation?
If possible, could you please share an example background script that generates and downloads an XLSX file?
Any guidance will be much appreciated.
CK
Bhuvan
Giga Patron
@chaitanya2948
Check this to generate XLSX file,
https://www.servicenow.com/community/servicenow-ai-platform-forum/generate-excel-file-xls-or-xlsx-ba...
If this helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
@chaitanya2948
Did you get a chance to review this ?
If my response helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
Hi Bhuvan,
Yes I tried the given script, not helped the file downloading with XLSX but not opening the file, getting error file corrupted or invalid file.
Chaitanya Kumar.
@chaitanya2948
check the below link I shared.
