Not able to use App engine studio in PDI
Murtaza Saify
I was not able to use app engine studio in PDI , then I released previous instance and got new one but same problem i am facing again, any solutions for it.
Hard luck mate. No other way, release and take lower version and then see
24 REPLIES 24
Sure Atul, I have reset the PDI , hope it works.actually earlier I had even released previous instance but got the same issue , is this issue with the brazil version?
I am at latest version and no issue. Hope reset works for you.
after reset , again facing same problem
sure thanks for the help will try my luck
