Not able to use App engine studio in PDI
Murtaza Saify
I was not able to use app engine studio in PDI , then I released previous instance and got new one but same problem i am facing again, any solutions for it.
Hard luck mate. No other way, release and take lower version and then see
24 REPLIES 24
Hi Atul Thanks for the help, service now troubleshoot the issue.
Aditya_hublikar
Hello @Murtaza Saify ,
Try once by reparing the App engine studio plugin :
If this helps you then mark it as helpful and accept as solution .
Aditya
Murtaza Saify
Hi Aditya,
On the application manager I am not able to see Quick actions through which i can go to repair
@Murtaza Saify,
Open Application Manager as admin user and check. Admin should have the right to repair applications.
Ehab Pilloor
Murtaza Saify
Yes Ehab I am opening app manager with the system admin role only but dont know why it is not showing
