Solution Design Documents for Flow Designer Implementation using App Engine
I am working on Fresh Implementation and will be serve as Solution Architect.
My Key Role would to design the Solution and Implement the same.
to Proceed with further i would need the basic key concepts to keep in mind
also an Sample Solution Design documents which needs to be Prepared for Solution
we are mostly creating a Multiple and Complex workflow with the help of App Engine so would need to sample documents and Tips Around it.
Dr Atul - LNG
Hi @Community Alums
To start working with a custom app, refer to the Now Create ( nowlearning.servcie-now.com/nowcreate) In this you will get the document under Asset , which can help you find the required documents.
