Variable Editor in Portal is not sync up with Variable Editor in Native View
12-17-2025 06:49 PM - edited 12-17-2025 06:50 PM
Hello Team,
I have a variable editor on Form Widget for created for Custom Application and i have added the same Variable Editor in Native View also , So the user will come and make changes on portal view in data variable editor which is not syncing up with the variable editor in Native View How to make it in sync up please suggest
lo
12-19-2025 01:34 AM
so that's a MRVS which has 2 variables.
Did you check any script is removing the other rows from that MRVS and keeping only 2 rows?
12-19-2025 08:32 AM
There is no script around this mvrs
I found this sync issue even for other variables
