09-06-2023 01:39 AM
Hi all,
I'm looking for guidance on Azure Stack HCI discovery. We have full Azure discovery running however I'm losing sight of previously discovered on-prem servers as they are migrated to HCI.
I am struggling to find any documentation on this topic. Does anyone have any experience in this area they could share?
Thanks in advance
01-30-2025 10:48 AM
I hope this helps, Im able to discovery HCI by making the following changes
1. Add a new Discovery Windows Classification
Then I made changes to the Patterns. Ive uploaded the update set containing the changes.
I cannot show a readable mapping but it was able to read through, create vm instances, clusters an other resources.
09-10-2026 03:15 PM
HI Chris, could you provide me with more information on how to do this discovery for Azure local, I am not able to download your screenshots, not having usccess with this cloud discovery process,
thanks
02-04-2025 01:37 AM
Looks like a great solution, thanks. It appears your using the SCCM Service graph connecter, is that correct?
I'm guessing that would be a pre-requisite for this approach?
02-04-2025 07:33 AM
We do have sccm integration, and no its not a pre-requisition, this is pure discovery only. If there is anything in the xml update set for sccm, I forgot to remove it, sorry.
02-04-2025 07:36 AM
doesnt look like I had any SCCM updates in the update set.
02-06-2025 01:35 AM
Thanks Chris, I'll give this a try and share the results.
