Variable type - Help required
Adil N
Hi all,
I am trying to figure out which variable type i need to select what i want (see screenshot is the ability to select quantity type if one the the options is chose
so for example if they choose monitor and keyboard they will have an option to input monitor x 4
keyboard x 3 etc
Any help is much appreciated
TIA
Kusal45
Hi @Adil N I suggest you to create a multi row variable set with two variables.
1)equipment to be moved - select box
2) Quantity - single line text
Check the attachment for your reference
Please mark my response as Correct and Helpful if it helped you.
thank you will give this a go
