Integration HUB ETL servicenow
Priyanka  B D
After cloning the instance Integration hub ETL plugin is not installed in the target instance.
Actually before clonning the plugin was installed in the source instance and related configuartions also was present in the source instance
Hi @Priyanka B D
The issue is that the plugin was not in the target when cloning happened, so the source didn’t have a place to add those files.
