How to configure the Inactivity notification for problem record (xanadu version)
I have created Inactivity event
and Notification on problem
under who will receive - Assignment group of problem is working expected
some of the fileds depricated in who will receive / adding scripts
please guide me
Thanks in advance
Hello @Community Alums ,
Thank you for the clarification, I understand the requirement now.
Please follow these steps:
1) Create a new Event Registry record. I have called it "problem_and_problem_task.inactivity" but feel free to pick any other name that is appropriate.
2) Create a new Script Action as shown below. It will listen to the "problem.inactivity" event that got triggered by your Inactivity Monitor. It then triggers our special "problem_and_problem_task.inactivity" event, with the Problem Task assignees passed as the first parameter.
Here is the script:
var grTask = new GlideRecord('problem_task'),
	assignees = [];
grTask.addQuery('problem', current.getUniqueValue());
grTask.addNotNullQuery('assigned_to');
grTask.query();
while (grTask.next()) {
	assignees.push(grTask.getValue('assigned_to'));
gs.eventQueue('problem_and_problem_task.inactivity', current, assignees.toString());
3.) Update your existing Notification:
  • change the Event to "problem_and_problem_task.inactivity"
  • enable the Event parm 1 contains recipient checkbox
Now the notification will be sent to the Problem Assignment group and the Problem Task assignees.
Robert
9 REPLIES 9
@Robert H
I also want to send same problem notification to problem task asigned to users
AmirMohamed01
Got you. It won't work this way.
You will need to create an event and a business rule that generates the list of users in an array.
Sure Can you guide me with script
Sure, please check this article:
Setup email notification using Business rule. - ServiceNow Community
If my answer helped you out, show some love by hitting "Accept as Solution" and "Helpful"! 💡💬 Your support not only boosts the community vibe—it means the world to me too! 🙌✨
swapnali ombale
Hi @Community Alums @ You should just have to dot-walk to the correct field. Your notification trigger should be on the problem task table, as should the email notification and template. In your notification record, you just need to populate the correct string into the 'User field' field. Assuming your problem task table is linked to the problem table with a field called 'u_problem', your 'User field' value should be 'u_problem.assigned_to'
Kindly mark my answer as helpful and accept solution if it helped you in anyway.
