How to write business roles based on fields between associated tables?
shiz
I have the following business roles.
var groupName = "G2U%";
            var typeName = "Organization";
            var f = 1;
            //現在のキャラクタの下にあるすべてのuserを取得して、に戻ります
            var userGroup = new GlideRecord("sys_user_grmember");
            userGroup.addQuery("user",u);
            userGroup.addQuery("group.name","NOT LIKE", groupName);
            userGroup.addQuery("sys_user_group_type.name",typeName);
            //userGroup.addQuery("group.name","<>",exceptGroup_1);
            //userGroup.addQuery("group.name","<>",exceptGroup_2);
            userGroup.query();
            while(userGroup.next()){
                var strGroup = userGroup.group;
                    // get group's user info
                    var g_member = new GlideRecord("sys_user_grmember");
                    g_member.addQuery("group",strGroup);
                    g_member.addQuery("user","<>",u);
                    g_member.query();
                    while(g_member.next()){
                        var strUser = g_member.user.sys_id.toString();
                        answer[f] = strUser;
                        f++;
But, userGroup.addQuery("sys_user_group_type.name",typeName) :This code is not effective.
The following are the field definitions for the table:
 How to modify the code to filter data with type 'organization' in the 'sys_user_group' table?
Hello @shiz ,
Use the below code. This works for me.
var f = 1;
var answer = [];
userGroup.addQuery("user", gs.getUserID());
userGroup.addQuery("group.name", "NOT LIKE", groupName);
userGroup.addQuery("group.type", 'f3dfc27ac32222103e1a76d4e40131c3'); // sys_id of organization
userGroup.query();
while (userGroup.next()) {
    g_member.addQuery("group", strGroup);
    g_member.addQuery("user", "<>", gs.getUserID());
    g_member.query();
    while (g_member.next()) {
        var strUser = g_member.user.getDisplayValue().toString();
		gs.info("sys_id - "+strUser);
        f++;
Output -
Group with members -
Script output
If my response was helpful, please mark it as correct and helpful.
Thank you.
OK,Let me tell you my needs.
            var f = 1;
            userGroup.query();
                    g_member.query();
                        f++;
Now ,  I have a group member table [sys_user_grmember], and now I want to filter out all the personnel information of the group members under the current user.
The filtering condition is that the name of the group table [sys_user_group] does not start with the group name "G2B%".
The 'type' in the group table must be of the 'organization' type
However, the 'type' field in the 'group' table is referenced from the 'group type' table, and 'sys_user_group' is referenced from the 'group' table.
So how can I modify the code to meet my needs
Please refer to the two pictures I posted at the top for specific table reference relationships.
Can you give me a specific solution?
I am checking...
Thank you.
Hello @shiz ,
var f = 1;
var answer = [];
userGroup.query();
    g_member.query();
        f++;
Output -
Script output
Thank you.
