Acessing variables in Advanced Reference Qualifier from a variable set
Javi2
I have a Record Producer with this structure.
Record Producer{
         Variable 1
         Variable Set {
                  Variable 2
Variable 1 is inside the record producer but Variable 2 is in a variable set. I want to use variable 1 value to filter Variable 2 using an advanced  reference qualifier but 'current.variables' refers to the variables in the variable set so I can't access variable 1.
Is there any way to achieve this?
Edit: This is a multi-row variable set.
Not sure if Variable 2 is the one that needs the reference qualifier, but according to the documentation Service catalog variable sets:
Note:
  • onSubmit catalog client scripts are not supported for a multi-row variable set.
  • Catalog UI policies and catalog client scripts defined at the item level are not applicable for variables in a multi-row variable set. Only those catalog UI policies and catalog client scripts defined within the multi-row variable set are applicable for variables in the multi-row variable set.
  • Scripts that are not included in a multi-row variable set cannot affect variables inside the multi-row variable set. Similarly, the scripts included in the multi-row variable set cannot affect the variables that are not included in the multi-row variable set.
  • Variables that are not included in a multi-row variable set cannot be used in dependent reference qualifiers for variables in the multi-row variable set. Similarly, the variables included in the multi-row variable set cannot be used in dependent reference qualifiers for variables that are not in the multi-row variable set. For a reference qualifier, the current row is the one that is being edited.
This may be why it is not working.
13 REPLIES 13
Note:
Javi2
Thanks! Seems that it's impossible to do then. I'll try alternative ways of doing this.
I was looking for a way to do this too...
I'm thinking that a relatively jank way to get this done might be:
Client script on the record producer makes a GlideAjax call to set a system property to the variable 1 value.
Script include being used in the reference qualifier for variable 2 can access the value in the system property.
I don't like the fact that this may be one of the few ways to get this done... but it's an idea anyway.
I know it has been 3 years, but i found a way around this and it's pretty simple. 🙂
In this example i needed the company sys id from the parent form to use as a Reference Qualifier in my Multi-row variable set.
Step 1
Create an extra variable in your Multi-row variable set. For example companyID. This field can be hidden (see step 2)
Step 2
Create a new client script (onLoad) in your Multi row variable set . For example:
function onLoad() {
	//Get company ID from parent form
	var companyID = parent.g_form.getValue('variables.company');
	//Set company ID to field
	g_form.setValue('companyid', companyID);
	//Hide company ID field
	g_form.setDisplay('companyid', false);
Step 3
You can now use this hidden field as a Reference Qualifier. For example: javascript:'company=' + current.variables.companyid + ';
I hope this helps!
Kind Regards,
Stefan
Stefan42
Step 1
Step 2
function onLoad() {
Step 3
I hope this helps!
Kind Regards,
Stefan
