‎01-28-2025 03:34 AM
Users with Role A should have write access to all field except Configuration Item on incident table and Role B should have write access to Configuration Item field and all other fields should be read only?
‎01-28-2025 03:41 AM
so what did you start with?
It's an easy requirement
1) field level WRITE on Configuration Item field -> Advanced script check logged in user
gs.getUserID() == 'user B sysId'
2) Table.* WRITE ACL and advanced script
gs.getUserID() == 'user A sysId'
OR
You can use onLoad client script if you don't want to mess with ACLs
‎01-28-2025 03:45 AM
Hi @sanyalshubh
you can perform the below way :-
Reference :-
1. Create new Table.None Read ACL and add both Role A and Role B which will allow both users to get row level read access.
2. Create new Table.None Write ACL and add both Role A and Role B which will allow them to get row level write access.
3. Create new Table.* Write ACL and add Role A only which will allow Role A users to edit all fields on incident table.
4. Create new Table.configuration_item Write ACL and add Role B which will allow only Role B to edit configuration item and it will not provide editable access to Role A users.
‎01-28-2025 03:51 AM
@sanyalshubh You need to create two write ACLs on the incident table.
1. incident.* In this ACL add the Role A in the role list
2. incident.configuration_item, Add Role B in the role list
‎01-31-2025 09:58 PM
1. incident.configuration_item, Add Role B in the role list.
2. incident.* In this ACL add the Role A in the role list.
