Advanced Reference isn't working on catalog variable
0890KM
Hey All,
I feel that I am missing something and I'm not sure what it is.
Here's my advanced reference qualifier on my catalog variable reference the sys_user table.
javascript: new getGroupMembers().getGroupMembersForIT(current.variables.assignment_group);
Here's the script include, which is global, client callable.
var getGroupMembers = Class.create();
getGroupMembers.prototype = Object.extendsObject(AbstractAjaxProcessor, {
            getGroupMembersForIT: function(assignmentGroup) {
                var arr = [];
                var grp = new GlideRecord('sys_user_grmember');
                grp.addQuery("group", assignmentGroup);
                grp.query();
                while (grp.next()) {
                    arr.push(grp.sys_id.toString());
					//gs.info("This are the values for the arr: " + arr);
                return 'sys_idIN' + arr.toString();
            type: 'getGroupMembers'
What am I doing wrong?
Chaitanya ILCR
Giga Patron
You are returning sysids of group members table
But you should return user sysids
                var arr = [];
                grp.query();
                    arr.push(grp.user.toString());
Try this
Chaitanya
I just had to redo it. I think there was something wrong with my update set. I backed it out and now it is working!
Thanks!
Cool @0890KM ,
Glad it's working now
Could you please accept the appropriate response as a solution and close the thread
it will help for the future readers
Chaitanya
