Advanced reference qualifier for variable in record producer
abjaffrey
Giga Guru
Hi all,
I have a use case in a record producer form
  • there is a requested for field which references the user table
  • there is an asset details field which references alm_hardware table
My need is that based on requested for, the asset details variable should only display the assets assigned to the selected user. can someone help me with this.
Advanced ref qualifier for the variable :
javascript: new getGroupMember().assignedAssets(caller_id);
SI:
    assignedAssets : function(getUser)
        var assets = [];
        var abc = new GlideRecord('alm_hardware');
        abc.addQuery('assigned_to',getUser);
        abc.query();
        while(abc.next()){
            assets.push('asset_tag');
        return assets;
2 ACCEPTED SOLUTIONS
Sebastian L
javascript: 'assigned_to='+current.variables.caller_id
Just add this to the reference qualifier of  your asset details
Best regards,
Sebastian Laursen
hi @Sebastian L
thanks for the response, it worked.
Sebastian L
Best regards,
Sebastian Laursen
hi @Sebastian L
