Advanced Reference Qualifier not working
Ryan S
Hi all. Working in a domain separated environment and have a requirement for the 'Assigned_To' field to be filtered based on the user being in 2 sys_user_group--the selected 'Assignment_Group' as well as another Visibility group. I've tried:
1. background script with hardcoded sys_ids. It works. I get the expected result which returns 1 user
2. all code in reference qualifier: Doesn't work. I get a list of all users
3. reference qualifier calling script include. Doesn't work. I get no users returned.
Assuming #3 is best approach, I've put that code below for review.
Assigned_To reference qualifier:
javascript: new AssignedToReferenceQualifier().getAssignedTo(current.company.sys_id,current.company.sys_domain,current.assignment_group.sys_id)
Script Include:
var AssignedToReferenceQualifier = Class.create();
AssignedToReferenceQualifier.prototype = {
    initialize: function() {
	getAssignedTo: function(myCompany, myDomain, myGroup) {
//query the Group Visibility Domain table to find the Visibility Group that grants access to the company's domain
    var visibilityGroup = new GlideRecord('sys_user_group_visibility');
    visibilityGroup.addQuery('sys_domain', myDomain);
	visibilityGroup.addQuery('group.name', 'CONTAINS', myCompany);
    visibilityGroup.query();
    while (visibilityGroup.next()) {
		var groupSysID = visibilityGroup.group;
		gs.info(groupSysID);
//now that we have the Visibility, we can filter the group membership table for the members of this group
    var userVisArray = [];
    var groupMembers = new GlideRecord('sys_user_grmember');
    groupMembers.addQuery('group',groupSysID);
    groupMembers.query();
	while(groupMembers.next()) {
		userVisArray.push(groupMembers.user.toString());
	var membershipResults = [];
	var strLength = userVisArray.length;
//now that we have members that are part of the Visibility group, confirm they are also part of the selected assignment group
	var userAssignArray = [];
	for(var i = 0; i < strLength; i++){
		var userID = userVisArray[i];
		gs.info(userID);
		var grMember = new GlideRecord('sys_user_grmember');
		grMember.addQuery('user',userID);
		grMember.addQuery('group',myGroup);
		grMember.query();
		while(grMember.next()){
			userAssignArray.push(grMember.user.toString());
	return 'sys_idIN' + userAssignArray.join(',');
    type: 'AssignedToReferenceQualifier'
Hi @Ryan S Please find the updated code -
    initialize: function() {},
        //only apply to specific groups, for now just going based on certain value in Group Name field
        var gr = new GlideRecord('sys_user_group');
        gr.addQuery('sys_id', myGroup);
        gr.addQuery('name', 'CONTAINS', '');
        if (gr.next()) {
            groupMembers.addQuery('group', groupSysID);
            while (groupMembers.next()) {
            for (var i = 0; i < strLength; i++) {
                grMember.addQuery('user', userID);
                grMember.addQuery('group', myGroup);
                grMember.query();
                while (grMember.next()) {
            var groupMembersArray = [];
            var grMembers = new GlideRecord('sys_user_grmember');
            grMembers.addQuery('group', myGroup);
            grMembers.query();
            while (grMembers.next()) {
                groupMembersArray.push(grMembers.user.toString());
            return 'sys_idIN' + groupMembersArray.join(',');
 first return statement should be inside the 'if' block.
13 REPLIES 13
Harsh_Deep
Hello @Ryan S
In the below line you are giving CONTAINS and you are passing myCompany but checking group.name, it should be company, myCompany
But in the reference qualifier you are passing company.sys_id
javascript&colon; new AssignedToReferenceQualifier().getAssignedTo(current.company.sys_id,current.company.sys_domain,current.assignment_group.sys_id)
So please use below code-
visibilityGroup.addQuery('company', myCompany);
Mark Correct if this solves your issue and also mark 👍 Helpful if you find my response worthy based on the impact.
Ankur Bawiskar
@Ryan S
please share how are you testing in background scripts and what values you are passing.
when advanced ref qualifier is called what comes in log?
Reus
@Ryan S
Can you please check the reference qualifier you giving. Shouldn't it be "current.variables.abc" ?
Ryan S
So @GopikaP's response fixed the issue and allows me to get the proper results. However, now that I get into testing I can find the requirement wasn't defined quite right. This whole logic needs to be applied only to certain Assignment_Groups. That's easy enough logically but I'm getting a compile error. Here's the updated code if folks don't mind taking one more pass. I'm thinking I've just got a bracket or semicolon or comma off somewhere. ServiceNow says error is at line 8 which is my commented line?!
	gr.addQuery('sys_id',myGroup);
	gr.addQuery('name','CONTAINS',<search text goes here in single quotes>);
	if(gr.next()) {
			grMember.query();
			else {
			grMembers.addQuery('group',myGroup);
			grMembers.query();
			while(grMembers.next()){
        if (gr.next()) {
                grMember.query();
            grMembers.query();
