Advanced Reference Qualifier with Script Include not working
Vinicius Luz
I have a reference field pointing to the sys_user table called "GP Approvers" attached to a MRVS on the portal
I need it to filter its choices based on a group, to show only this group members. Here's my code
Script Include:
getGPapprovers: function() {
        var users = [];
        var gr = new GlideRecord("sys_user_grmember");
        gr.addQuery("group", "2d5b43881b864110d9ad0dcbe54bcb5c");
        while (gr.next()) {
            users.push(gr.getValue("user"));
        return 'sys_idIN' + users.join();
Field:
In my understanding this is properly set, unless I'm not seeing the error. Or even the MRVS doesnt accept this setup ...
Whats wrong ?
Ankur Bawiskar
are you using this in scoped app?
if yes then getValue() won't work
use this
        var users = [];
        while (gr.next()) {
            users.push(gr.user.toString());
Shakeel Shaik
Hi
Script Include:
var CriacaoUtils = Class.create();
CriacaoUtils.prototype = Object.extendsObject(AbstractAjaxProcessor, {
        var users = [];
        gr.addQuery("group", "<Group_Sys_id>");
        while (gr.next()) {
            //users.push(gr.user.sys_id);
        return users.toString();
    type: 'CriacaoUtils'
Reference Qualifier:
sys_idINjavascript: new CriacaoUtils().getGPapprovers();
Please check and Let me Know.
Thanks 🙂
Shakeel Shaik 🙂
Ankur Bawiskar
use this
        var users = [];
        while (gr.next()) {
