After Cloning Servicenow instance facing Flow designer issue.
03-30-2025 10:35 PM - edited 03-30-2025 11:52 PM
Hello everyone, We have cloned our ServiceNow instance with Production. After cloning I'm facing below issue for all the flows & subflows. Error :- "Your flow cannot be found. Flow sys_id:nnot invoke "com.glide.flow_design.action.model.Flow".
Also, after creating a new flow & selecting a trigger getting "Internal Server Error".
Thanks in advance.
03-30-2025 11:43 PM
Hello @Dr Atul - LNG , I have tried repairing the plugin but still facing same issue.
Thank you for your response.
03-31-2025 12:01 AM
Hi @Rahul63
Thanks for the update. Please log a support case now, as the plugin update didn’t work. There might be some missing code from the upgrade, and the support team can assist with this.
03-30-2025 10:53 PM
Hi @Rahul63
Are you facing this issue on all the flows or just with the specific flow?
If it's on the specific flow, then it could be because of invalid data pill reference in any one of the flow actions. i.e one or more inactive fields might be referred in any of the flow actions can caise this issue.
Reagrds,
Siva
03-30-2025 10:59 PM
Hello @J Siva, I'm facing this issue for all the flows & sub flows.
03-30-2025 11:10 PM
Better you can raise a support case with vendor and see what they suggest.
Siva
