04-29-2021 01:12 AM
Hello, everyone
My problem is that every flow is not automatically triggered in my personal instance, but they are all in queued state. But when I test them from flow designer they all work.
04-29-2021 10:43 PM
Check in your sys_trigger, there should be a job called - Flow Engine Event Handler. If this is stuck try to nudge it. Also check event queue [sysevent] for backlogs.
02-24-2022 08:14 AM
The flow being queue is a sign the events related to flow is not processing.
1. Check in your sys_trigger, there should be a job called - Flow Engine Event Handler. This is responsible for running the events related to flow.
2. Check this Job and see if the next action is in the near future and the state is running or ready
3. if not then set the next action to the future and see the flows are getting fired.
02-25-2022 01:49 AM
Thanks a lot for your quick reply. I checked this a few times. There is one Flow Engine Event Handler running (1 of 39) for 2 days now. All other are in red Ready.
But all Flows are queued, not a single one gets processed.
When I tried to change the Next action time to something in the near future of a few of the others the State changes from a red Ready to a black Ready, but no one of them are starting?!
02-25-2022 02:52 AM
It might take some time becz all the flows are queued for you so the events job should process these flows. Better raise a HI case and get their review on your instance and process the events in a faster way.
02-25-2022 03:38 AM
A HI case won't help here because it's a Personal Developer Instance.
Kind regards,
Mark
02-25-2022 06:21 AM
Oh! I didn't know this was on PDI. I thought it was on company instance.
