Approval using for each in flow design
11-08-2023 11:01 PM - edited 11-09-2023 04:31 AM
There's a variable with type as list collector, users can select multiple servers. Based on the servers selected, it should trigger the approval for the server owner. I have a flow design along with the subflow.
This is in the flow:
This is the subflow:
After submitting the request, in the flow context:
Please help me in resolving this issue. Thanks in advance.
@Ankur Bawiskar @Sandeep Rajput @Dr Atul - LNG @Hemanth M @pavankumar17 @Anurag Tripathi @AshishKM
11-09-2023 01:18 AM
You're using Look Up Record, the correct one is Look Up Records. 😋
Cheers,
Tai Vu
11-09-2023 01:39 AM - edited 11-09-2023 01:51 AM
@Tai Vu , Thank you. This is working now. But it's triggering the approval, one after another, is it possible to trigger approval parallelly for all the approvers?
But once everyone has approved the request, the flow is not going to the next action
11-09-2023 02:33 AM
Why not? There you go!
Just collect the Approver sys_id. Then do Look Up Records to User [sys_user] table.
Drop the User Records into the Ask for approval step.
Cheers,
Tai Vu
11-09-2023 02:16 AM
