Approval Wait for Condition Stuck and will not move forward
Tony Landowski
I have the below Wait for condition that I am trying to find out why it will not move forward to the next step of the workflow.  Can someone please help.  Note: the need is to wait for both approvals before moving to the next step.
Script:
var rec = new GlideRecord('sysapproval_approver');
rec.addQuery('sysapproval', current.sys_id);
rec.addQuery('active', true);
rec.query();
if(rec.hasNext()){
answer = false;
else{
answer = true;
Workflow:
Ankur Bawiskar
Your workflow is on RITM table but the actual update will happen on Approval table.
So workflow won't know when to process the wait for condition.
Wait for condition is processed when update happens on that record in this case RITM
So workaround is create after update BR on sysapprovap_approver table and mimic the update on RITM record so that workflow evaluates the condition and proceeds if all approvals are done
Condition: current.sysapproval.cat_item.name == 'Your Catalog Item Name Here' && (current.state == 'approved' || current.state == 'rejected')
Script:
	// Add your code here
gr.addQuery('sys_id',current.sysapproval);
if (gr.next()) {
 new Workflow().broadcastEventToCurrentsContexts(gr, 'update', null);
})(current, previous);
Also update your wait for condition script as below
answer = false;
rec.addQuery('state', 'requested'); // check if any approval for this RITM is in requested state
rec.query();
if(!rec.next()){
answer = true; // if not found then proceed
Tony Landowski
Thank you both, very helpful.
@Tony Landowski
Glad to help.
If my response helped you please mark my response as correct & helpful so that this thread can be closed and others can be benefited by this.
