Array help-I need to take an array, compare against reference table, to create Approvals
Shane J
I have an intake form with a List Collector variable (Variable: list_role) on it which references a table (Table: u_role).
I have another table (Table: u_approvers1) that has a reference to the same table.
Within this item's workflow, I need to be able to take the values from list_role, compare them against the tables in the u_approvers1 Table, and create Approval records for each.
What's the best way to attack this?  I have the start of what i think is needed to pull list_role apart but after that I'm not sure what to do with it.
var list = current.variables.list_role.toString();
var array = list.split(",");
for (var i=0; i < array.length; i++) {
var rec = new GlideRecord('u_approvers1');
What do I do here?
I understand that, but if you're using a Group Approval activity, that requires the returned array contain group ids. Because you're using user ids, I think you want to use a User Approval activity instead of a Group Approval activity.
See: Group Approval and User Approval
Group Approval says
User Approval says
So, if you're using sys_ids that are sys_user records, you want to use a User Approval activity.
approval.u_approver is a Reference to the User table.  I've checked the gs.log and it is spitting out sys_id that match correctly to the User table.
Group Approval says
User Approval says
Thanks Matthew, that was the issue.  Script works fine when it's in the right kind of Activity.  😉
