ATF help
TStimple
I am a Newbie and hoping to get assistance with what seems would be an easy ATF test to create.
The objective is to simply insert/open an Incident record, and then add an item to the affected CI (related) list.
I can confirm the list is visible on the form in step 4, but Whenever I use the step 5 'Click a UI action on a related list' I get an error that the 'List cannot be found on the open form'
What am I missing?
I am still looking for some help with the question above, please.
How do I populate the forms that open when I click the Add or Edit buttons on a related list?
To answer to your question to
1) Need to use Related list fist to clickon 'edit' andor 'new' button
2) Need to use Click UI component for your query and drag your selection from left to right and Save
Attached the screenshot for your reference. Please contact me directly as an ATF expert / Architeh I can help you with.
If my response has resolved your query, please consider giving it a thumbs up ‌‌ and marking it as the correct answer‌‌!
Nayan Patel
If my response has resolved your query, please mark it Helpful by giving it a thumbs up and Accept the Solution
@Nayan ArchX Thank you for this. I'm running into issues with step 10. I want to use a new user that I created, rather than populate with an existing user. When I try to reference the new user, it won't let me. The document_id option is grayed out. Any ideas? Thanks.
Nayan ArchX
Nayan Patel
