‎08-19-2015 04:22 AM
Hi there,
I'm figuring out the best way to do this..
In my form, I have 2 fields: caller and hospital.
Caller refers to the users table, Hospital refers to the company table.
My goal is: whenever I populate the caller field, the system needs to lookup the hospital of that caller and needs to auto-populate that.
Example: Customer X is part of Hospital X. Customer X is the caller so will be populated in the caller field. The system recognizes that Customer X is part of Hospital X so hospital will be Hospital X.
Hope you guys can help me out!
‎08-21-2015 06:53 AM
We got it working!
Client script:
var ga = new GlideAjax('GetCustomerData');
ga.addParam('sysparm_name','getFieldValue');
ga.addParam('sysparm_field','u_reference_1');
ga.addParam('sysparm_user_id', g_form.getValue('caller'));
ga.getXML(DoSomething);
function DoSomething(response) {
var company = response.responseXML.documentElement.getAttribute("answer");
g_form.setValue('company',company);
Script include:
var GetCustomerData = Class.create();
GetCustomerData.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
getFieldValue: function() {
var user = new GlideRecord('x_medt2_ihs_customers');
user.get(this.getParameter('sysparm_user_id'));
if(! user.sys_id){
return false;
return user[this.getParameter('sysparm_field')];
Thanks everybody for the great help on this!
‎08-20-2015 02:16 AM
g_form.getReference() is still not recommended because it returns the entire record rather than just the field you need.
This is OK at the start, but as you keep filling up your client scripts with getReference() your system will degrade and eventually become slow, resulting in end user complaints. Alas, it is not good practice to use getReference().
My recommendation is to create a re-usable AJAX script to get data from any given table, reducing the overhead of developing ajax scripts.
In my instances I have reduced GlideAjax calls like this to one line of client script code using these methods.
‎08-20-2015 02:45 AM
Ok, it's truth that it returns the whole GlideRecord on that case, which it would be, depending on the data of the record, a little bit slower than the solution with AJAX script, which is definatelly the most efficient.
The solution you did on your instances is so elegant, could you share with us that "Universal script" of the place where you found it?
Thank you!
We got it working!
Client script:
Script include:
if(! user.sys_id){
return false;
‎05-09-2017 11:44 PM
Hi ,
I have a issue. I need to populate a reference field based on the location of the logged-in user.
ex- if the logged-in user is from X country ,the fulfillment group should populate Y.
and if logged-in user is from A country, the fulfillment group should populate B.
Thanks.
