Autocomplete/suggestions in Flow Designer Scripting Not working
Justin Lee2
We have a non-prod environment that is in Utah.  In flow designer, any time I want to script a value (toggle scripting) the suggestions do not load.  (see image below)  This makes it impossible to do any scripting as there isn't a way (that I know of) to get the variable/pill names.  (they are typically like _2__something_xyx...)
Any ideas on what I should check to get it working?  If not, do you know of a way to get the variable names in flow designer so I can just type them in until this gets resolved?
Justin Lee2
After upgrading to Vancouver, it worked for 2 days - then broke again.  We created a ticket with ServiceNow, and as Daniel mentioned, they are aware of the issue and are working on a fix.
17 REPLIES 17
ChristianF
We have the same problem with a non-prod instance on Utah Patch 6. Another non-prod instance on Utah Patch 4 Hot Fix 2b is working fine. We have the feeling the problem occured since Patch 6 (or maybe 5).
This is consistent with our experience, too. We have the issue on a Utah Path 6 instance. But we also have other Utah Path 6 instances (with a different set of plugins) without the issue.
Eddloupe
Our low env is in vancouver and it is now working on us either.
I'm experiencing the same issue, If you hover over anything in the inline script, you just get a 'loading' preview.
We're on Utah patch 7
Working inline script editor (Utah patch 4 PD, all browsers)
Broken inline script editor (Utah patch 7 Customer environment, all browsers)
