Autocomplete/suggestions in Flow Designer Scripting Not working
Justin Lee2
We have a non-prod environment that is in Utah.  In flow designer, any time I want to script a value (toggle scripting) the suggestions do not load.  (see image below)  This makes it impossible to do any scripting as there isn't a way (that I know of) to get the variable/pill names.  (they are typically like _2__something_xyx...)
Any ideas on what I should check to get it working?  If not, do you know of a way to get the variable names in flow designer so I can just type them in until this gets resolved?
Justin Lee2
After upgrading to Vancouver, it worked for 2 days - then broke again.  We created a ticket with ServiceNow, and as Daniel mentioned, they are aware of the issue and are working on a fix.
17 REPLIES 17
Daniel Vargas
Please post if someone has found a solution or workaround other than upgrading to Vancouver.
A family upgrade is not currently an option in my organizations environment.
We were upgraded to Utah Patch 7 yesterday.
EDIT:
ServiceNow Support states,
1. Wait for fix in a future patch
2. Fix is tentatively scheduled for Utah Patch 8 and Vancouver patch 3 (Please note that this is subject to change)
NWTMark
Can confirm we also have this problem in Vancouver Patch 2. It's forcing me to mock up some flows in my own PDI just so I can see the right values for the fd_data object.
Justin Lee2
Yeah they said they're planning to fix the issue on Vancouver Patch 3
Do you have a KB or PRB number for it that you can share?
Thanks.
