By using a Catalog Client Script, the Record Producer is not submitting
Sagar Manocha
I've written a Catalog client script for a Record Producer but when i am using the script, the Record is not submitting.
Below is the code present that i am using:-
function onLoad(){
g_form.getReference('caller_id', somefun);
var status;
function somefun(req){
if(req.vip=='true'){
g_form.addInfoMessage("inside if");
//g_form.setValue('urgency',6);
//g_form.setReadOnly('urgency',true);
else{
g_form.removeOption('urgency',6);
Regarding the two lines of code which are commented right now, if I am removing the comments from any one the line, the Record Producer is not working. Below is the screenshot of the Record Producer after clicking the submit button.
Shweta KHAJAPUR
Hi Sagar,
Below code worked for me,
function onLoad() {
var caller = g_form.getReference('caller_id', doAlert);
function doAlert(caller) {
if (caller.vip == 'true'){
var x = 2;
g_form.setValue('urgency',x.toString());
}else{
var y = 6;
g_form.setValue('urgency',y.toString());
22 REPLIES 22
The script that i posted in my query is the onLoad client script that I am using. Attaching a screenshot again for your reference. 🙂
in line 4 you should be setting a variable value
var req= g_form.getReference('caller_id', somefun);
Can you switch getReference and setVisible. first write getReference and then setVisible.
Gareth, I've already tried that. By using that, m not getting any value in the variable which m equating with the getReference method.
And Shweta, tried switching the lines as well. Not working
Line 6 shouldn't have quotations around 'true'
If (req.vip == true){....
