By using a Catalog Client Script, the Record Producer is not submitting
Sagar Manocha
I've written a Catalog client script for a Record Producer but when i am using the script, the Record is not submitting.
Below is the code present that i am using:-
function onLoad(){
g_form.getReference('caller_id', somefun);
var status;
function somefun(req){
if(req.vip=='true'){
g_form.addInfoMessage("inside if");
//g_form.setValue('urgency',6);
//g_form.setReadOnly('urgency',true);
else{
g_form.removeOption('urgency',6);
Regarding the two lines of code which are commented right now, if I am removing the comments from any one the line, the Record Producer is not working. Below is the screenshot of the Record Producer after clicking the submit button.
Shweta KHAJAPUR
Hi Sagar,
Below code worked for me,
function onLoad() {
var caller = g_form.getReference('caller_id', doAlert);
function doAlert(caller) {
if (caller.vip == 'true'){
var x = 2;
g_form.setValue('urgency',x.toString());
}else{
var y = 6;
g_form.setValue('urgency',y.toString());
22 REPLIES 22
Set UI type to ALL in catalog client script.
Yes Shweta, I've already set it to All. Still not working 😞
Is your variable is reference field then use  javascript:gs.getUserID()
Tried that as well. But with getUserId(), the getReference method is itself not working. It is working on getUserName() only.
Also try something as below,
function onLoad(){
var vip1 = g_form.getReference('caller_id').vip;
if(vip1 == true){
else{
