calling the system properties in flow designer inputs
LaraReddy
We have created Two "String" system properties.
In flow designer we created Two input variables.
And now we want to call those Two properties in flow designer and get the outputs.
Can anyone please help us here.
Advance thanks.
14 REPLIES 14
You can create a script step and write the following script
Other option is to create a Lookup record step to get the value
If this will solve your query, mark this as correct & helpful.
HI  Anand,
Is there any way to get the Two system properties in one script action.
Currently we're getting one property right, to get another one do we need to create another script action ???
Thanks.
you can use the same script action and write the script in the same one.
use GlideRecord and get the other property, create two output variables and set the values to different properties values.
Hi Anand,
Please check out the steps once.
Inputs image below:
Could you pls check the below script:
// ... code ...
var value = '';
var gr = new GlideRecord('sys_properties');
gr.addQuery('name','default_ship_from_warehouse');
if(gr.next())
value = gr.value.toString();
var value1 = '';
gr.addQuery('name','default_return_to_warehouse');
if(gr.next())
value1 = gr.value.toString();
output.from_ware_house = value;
output.return_ware_house = value1;
})(inputs, outputs);
And the output variable image below:
Advance thanks.
Looks Good
Change output to outputs.
You can test it using test button to validate the output.
