Catalog client script to populate reference variable not working in Service Portal
Maria DeLaCruz
I've created the following onLoad catalog client script to auto-populate a reference variable, and it works great on the Desktop UI, but not the Service Portal UI.  Is there something in this script that is not supported in the Service Portal?  I do have "All" selected for the UI type.
function onLoad() {
var proj = [];
var gr = new GlideRecord('u_project_name');
gr.addQuery('u_used', false);
while(gr.next())
proj.push(gr.u_number.toString());
proj.sort(function(a, b){return a-b});
//gs.print(proj[0]);
var confidential = new GlideRecord('u_project_name');
confidential.addQuery('u_number', proj[0]);
confidential.query();
if(confidential.next())
g_form.setValue('project_name', confidential.sys_id);
Any assistance would be greatly appreciated!
Maria
Mike Patel
Tera Sage
Doing Glirerecord query is not recommended in client script. Use GlideAJAX instead and script include
Can you also share ConfidentialProject script includes
Yes.  Here's the script include:
Client callable: true
var ConfidentialProject = Class.create();
ConfidentialProject.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getProjectName: function() {
var confProject = "";
var proj = [];
while (gr.next()) {
return a-b;
var conf = new GlideRecord('u_project_name');
conf.addQuery('u_number', proj[0]);
conf.query();
if(conf.next()){
confProject = conf.sys_id;
return confProject;
sachin_namjoshi
Mega Patron
Modify your code like below,
function onLoad() {
var proj = [];
while(gr.next())
confidential.addQuery('u_number', proj[0].toString());
Alsom Instead of gliderecord, it's recommended use glideajax in your client script.
Sachin
