Changing Flow Names in Flow Designer
KUDO1
I have a question about changing the flow name in Flow Designer.
My instance is in Tokyo.
After creating a flow as shown below, when I try to change the flow name, it does not change.
Not only me, but other members working together are having the same problem.
1) Create a new flow in Flow Designer.
2) Change the flow name on the Flow Properties screen.
 -> The flow name on the screen does not change.
3) Open the Flow Properties screen again and check the flow name.
 The flow name is back to what it was before the change.
Does anyone know the cause or how to fix this?
Is this a bug in Snow from the Tokyo version?
I thought I could change it normally in previous versions.
Thank you in advance.
Tsutomu Kudo
However, the following page states that the header name can be changed from the main header properties screen, but currently the header name cannot be changed.
Do you know why?
URL:https://docs.servicenow.com/bundle/tokyo-application-development/page/administer/flow-designer/task/...
