Client script help
servicenow_devo
Hi Team,
I have requirement for service catalog. I would need to populate list of assigned assets to the user.
It should be a onchange client script and if user has any assets assigned should populate and show up the name of assets.
Thanks in advance
Thankyou
VishalB06557037
Hello @servicenow_devo
I have achieved this by using variable type as a 'HTML'.
Can you check if this works for you....!!
Step 1 : Created two variables
A] Name : User (user)
     Type   : Reference
     Table  : sys_user
B] Name : My Assets (my_assets)
     Type   : HTML
     Read only : true
Portal view :
Step 2 : Write Client script and script include as below
Script include :
Name - assetDetailUtils
var assetDetailUtils = Class.create();
assetDetailUtils.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getAssetDetails: function() {
		/*1. Get user from client script */
        var user = this.getParameter('sysparm_user');
        /*2. Declare one array to send results */
        var assetarray = [];
		/*3. Glide record on Hardware table - you can use your table */
        var grHardware = new GlideRecord('alm_hardware');
        grHardware.addQuery('assigned_to', user);  //query with assigned to is user
        grHardware.query();
        while (grHardware.next()) {
           /* 4. Get detalis in JSON */
            var assetDetails = {};
            assetDetails.asset_tag = grHardware.getValue('asset_tag').toString();
            assetDetails.serial_num = grHardware.getValue('serial_number').toString();
			/* 5. Push the JSON in Array */
            assetarray.push(JSON.stringify(assetDetails));
        /* Return Array */
        return assetarray.join('|');
    type: 'assetDetailUtils'
OnChange client script on 'User' variable :
    var user = g_form.getValue('user');
    var values;
    var ga = new GlideAjax('assetDetailUtils');   //script include
    ga.addParam('sysparm_name', 'getAssetDetails');  //script include function
    ga.addParam('sysparm_user', user);
    ga.getXMLAnswer(callBack);
    function callBack(answer) {
        var result = answer.split('|');
        for (var i = 0; i < result.length; i++) {
            if (values) {
                values = values + '<p>' + 'Asset Tag : ' +  JSON.parse(result[i]).asset_tag + ' | ' +'Serial Number : '+   JSON.parse(result[i]).serial_num +'</p>';
                values = '<p>' + 'Asset Tag : ' +  JSON.parse(result[i]).asset_tag + ' | ' +'Serial Number : '+   JSON.parse(result[i]).serial_num +'</p>';
        g_form.setValue('my_assets', values);
Output :
Hope this works...!!!
Vishal Birajdar
ServiceNow Developer
- Socrates
Hi @Manoj89
It's still not giving me required output. If you can help me with script Include and code it will be helpful.
Thankyou
VishalB06557037
Hi @servicenow_devo
Rich text label is just a label to provide some message or information.
You cant change it dynamically.
If you want to display asset assigned to user then use Multi Row variable set.
Vishal Birajdar
- Socrates
VishalB06557037
     Type   : Reference
     Table  : sys_user
     Type   : HTML
     Read only : true
Portal view :
Script include :
        grHardware.query();
        /* Return Array */
    var values;
            if (values) {
Output :
Vishal Birajdar
- Socrates
