Close incident after 7 days of being resolved using flow designer.
04-08-2025 07:39 PM - edited 04-08-2025 07:40 PM
04-08-2025 09:50 PM
Requirement - it should trigger a notification to assignee of major incident after major incident been resolved past 7 days.
via notification assignee will take further manual action.
04-08-2025 09:52 PM
Hello @bgulshan
Did you try my latest update ?
Kindly mark my answer as helpful and accept solution if it helped you in anyway. This will help me be recognized for the efforts and also move this questions from unsolved to solved bucket.
Shivalika
My LinkedIn - https://www.linkedin.com/in/shivalika-gupta-540346194
My youtube - https://youtube.com/playlist?list=PLsHuNzTdkE5Cn4PyS7HdV0Vg8JsfdgQlA&si=0WynLcOwNeEISQCY
04-08-2025 10:21 PM
I am able to select Relative Before 7 Days ago
Try to clear cache using cache.do and then logout and login again
04-08-2025 08:25 PM - edited 04-08-2025 08:29 PM
Thanks @Shivalika,
Requirement was to trigger notification if incident been resolved 7 days in past
For example, incident should be resolved on 2 April 2025 to trigger the notification on 9 April 2025
Please provide way to achieve this requirement
grateful for your quick response
04-08-2025 08:34 PM
Ok @bgulshan Its past
Then change it to
"RESOLVED is relative before 7 DAYS AGO"
Shivalika
