Code Help in Regex
ST9
I wanted to extract a Order Number(123456789) and save that text to a particular custom field. if the order number is empty the, the custom field should be empty as well.
Example this-
Order Number: 123456789
Candidate Name: Albert Test
Profile link: check
Hello
First Advantage is conducting a background check..
How do i achieve this using regex or any other way?
var des= current.description;
var index = des.indexOf("Order Number:");
var orderNum = des.substring(index+14, index+23);
	current.u_order_number= orderNum;
Hi @ST9 ,
You can modify the regular expression pattern and use the ^ and $ anchors.
Here's an updated example:
var des = current.description;
var orderNumRegex = /^Order Number:\s*([A-Za-z0-9]+)$/m;
var match = orderNumRegex.exec(des);
var orderNum = match ? match[1] : '';
current.u_order_number = orderNum;
In the updated code:
  • The ^ anchor at the beginning of the pattern ensures that the match starts at the beginning of a line.
  • The $ anchor at the end of the pattern ensures that the match ends at the end of a line.
  • The m flag is used after the closing / to enable multi-line mode so that ^ and $ match the beginning and end of each line in the input string.
If my response was helpful in resolving the issue, please consider accepting it as a solution by clicking on the ✅Accept solution button and giving it a thumbs up 👍. This will benefit others who may have a similar question in the future.
Thank you!
Ratnakar
11 REPLIES 11
ST9
Hi @Ratnakar7 :
The above code does not work if there is space before the order number
Example-
 Order Number: 123
Candidate Name: THOMAS BERNIER
Profile link:
Hello
Could you please help?
Hi @ST9 ,
You can modify the regular expression pattern to include optional spaces before the number. Here's an updated code snippet that should work:
var orderNumRegex = /^\s*Order Number:\s*([A-Za-z0-9-]+)/m;
In this updated code, \s* allows for zero or more spaces.
Ratnakar
