Converting a sys_id to a string via a flow not working
Biddaum
I have a field on an asset record that is a list collector, storing users that have access to that asset.
I have a flow that is sometimes going to update/rerecord the list of users. In order to do that I am deleting the current users and updating the record with the new list from a flow. Everything works as I'd like to that level, however I want to add a work note simply saying that the list is being updated as part of a flow, record that flow name and record details, along what the list of users were before clearing the list, however I can't seem to be able to get the list via the flow.
Here are some details:
Table: alm_asset
Field name: u_asset_users (Asset Users)
Flow variable: existing_user_list (Existing user list)
I am doing a lit collector convert to array and a "for each" loop in order to get the user list and convert into their names, to add as a string on the work note field, however the "look up record" action keeps getting a "No record found in look up record action" error.
Flow screenshots:
Ideas?
Ankur Bawiskar
@Biddaum
you should use Lookup Records with this
Sys id [IS ONE OF] Get Catalog Variable->List variable
Then iterate those records using For Each
Ankur Bawiskar
@Biddaum
something like this and then use Update Record on that Lookup Record in Step 4 as Step 5 so that you can update the field you want
shubhamseth
@Biddaum
Final Flow Steps Summary
  1. "Get Record" Action: Fetch the alm_asset record.
  2. Store u_asset_users in existing_user_list (Sys IDs string).
  3. Convert List to Array: Split the Sys IDs into an array.
  4. Loop Through the Array:
    • Use "Look Up Record" on sys_user where sys_id = current array element.
    • Append user.name to a variable.
  5. Update Work Notes with:
    • Flow execution details.
    • Previous user list before clearing.
diego2_898
yes me too
