Create CRQ using Flow Designer Action
Rakshanda Kunte
I have created the Flow Designer Action, which creates 'Demo' type of change request.
But, after creating CRQ, some fields are by default read only.
I checked, there is no Client Script/UI Policy/ACL available in the instance which will make other fields read only (on load).
Is there any way to remove read only functionality from the fields?
Thank you..!!
Hello @Rakshanda Kunte
The "watch" option will be available in UI16 that too when it is not opened in new tab. It won't be available with Now Experience.
You can switch to UI16 to debug and get back to Now Experience from you profiler UI preferences.
By the way what is the plugin name that brought this "Demo Change" model?
Anvesh
Ankur Bawiskar
@Rakshanda Kunte
this is nothing to do with flow designer.
Did you check those fields are read-only because of some Data policy or read-only from dictionary level?
Certified Technical Architect  ||  9x ServiceNow MVP  ||  ServiceNow Community Leader
