Creating a workflow using flow designer
01-29-2024 03:54 PM
Hi
I am needing to create a simple workflow using flow designer, I could use workflow editor for this but I want to get into the habit of using the flow designer and needing help
Its a simple workflow where only HR manager group members can create a account provisioning/de-provisioning from the portal and when all mandatory fields are entered, and submitted, then the Service Task Catalogue is created and assigned to the Human Resource Management Group
And as a member of the Human Resource group, when I assign the task to myself and I set the state to closed, then the service task catalogue is closed
Please see the form below
Thank you
01-29-2024 10:35 PM
no worries,
use "get catalog variables" action and then point it at your catalog item, select the variables you want to capture.
e.g.
then you can access them in your task creation item like so:
