‎09-13-2020 10:45 PM
Hi
I want to try out the data source of type 'Custom (Loaded from script)'. Is there any place where I can get a sample of the same to get the basic idea of its syntax and other rules?
Scripting and Coding
‎09-13-2020 11:18 PM
at the official documentation there is an example, feel free to use it:
If I have answered your question, please mark my response as correct and/or helpful.
Thank you very much
Cheers
Alberto
‎09-14-2020 04:31 AM
It seems the instance I am trying to implement on is not Orlando, so it lacks the 'Custom()load by script' feature.
I actually want to populate multiple CI classes based on a data in custom table.
What would be the best approach for this?
‎09-14-2020 05:14 AM
you can use Data source and transform map for this approach.
Or if this is one time job then write a one time schedule job and run it against your custom table.
‎09-14-2020 09:40 PM
How can we add custom table to a Data source?
‎09-14-2020 10:24 PM
you can create data source, create transform map. transform map would be on your custom table where you want to load the data
‎09-15-2020 09:56 PM
Hi Ankur
Let me clarify my requirement
I want to take data from table X to one of the CI class.
In that case how can we configure a data source(for table X). Also I want this to happen every time a record is inserted to table X?
