03-20-2025 04:51 AM
Hi Everyone,
Can anyone please help me out how to deactivate the groups which has NO Users using Flow Designer. I have tried but not able to get the desired results. Please find the attached screenshot for reference.
Thanks in advance
03-20-2025 08:04 PM
Hope you are doing good.
03-20-2025 06:31 AM
03-20-2025 06:44 AM
it's fine.
For verification do this
1) in step 1 give condition as 2 groups, 1 Group which has members and 2nd Group which has 0 members
something like this
Name [IS ONE OF] Group ABC,Group DEF
If the logic works then it means it will work for all groups
once testing is done then remove that condition from Step 1
03-20-2025 06:49 AM
the logic I shared worked fine, so it should work for you as well.
I just tested with similar steps which I shared. 1 Group with member and 1 Group with no member
It deactivated the group with no member
03-20-2025 08:04 PM
