06-17-2020 12:35 AM
hello,
I have written two inbound actions on tables - incident and u_new_call
Please find the script( This is same for both only written on different tables )
current.short_description = 'Callback request submitted via Voicemail';
current.description = 'Please listen to the voicemail.\n\n' + email.body_text + '\n\n Once called change the log type to denote that follow up was made';
current.u_contact_phone_number = findContactPhone(email.subject);
current.contact_type = 'Callback';
current.assignment_group = new ScriptIncludeName().byPassingName('Group name'); // Script include and group name changed with Generic names
current.insert();
function findContactPhone(subjectLine){
var phoneNumber = /\d+/g.exec(subjectLine);
return phoneNumber.toString();
Both new call record and incident is not getting created giving below message:
ServiceDesk New Call Callback : did not create or update u_new_call using current
ServiceDesk New Incident Callback : did not create or update incident using current
How can i resolve this issue?
06-17-2020 07:35 AM
Hi Nikita,
when match not found it returns null and hence breaking
we can handle this as below
var subjectLine = email.subject;
var phoneNumber = subjectLine.match(/[+](1-)(\([0-9]{3}\)|[0-9]{3}-)[0-9]{3}-[0-9]{4}/);
// check if not null
if(phoneNumber!=null){
current.u_contact_phone_number = phoneNumber[0]; // using the 1st array element
current.assignment_group = current.assignment_group = new ScriptIncludeName().byPassingName('Group name');
current.insert();
06-17-2020 02:00 AM
Hi Nikita,
seems some issue with the regular expression.
Glad that it worked
Please consider marking reply as ✅Correct & 👍Helpful.
06-17-2020 02:27 AM
But how do I fix this issue ?? I commented for testing.
But i need to map the phone number in both.
06-17-2020 02:36 AM
Hi Nikita,
what is the format for phone number?
based on that regular expression can be used
Regars
06-17-2020 03:26 AM
here is the format -
| +1-918-000-0000 |
06-17-2020 03:53 AM
Hi Nikita,
below should retrieve the phone number properly
return phoneNumber[0].toString();
