Difference between client script and business rule
What is the difference between client script and business rule apart from the one that client script runs on the form and business rules on the database. Suppose I have a business rule which prints a message when one field in the form is empty and I have a client script that does the same thing. How do I come to know whether it is the Business rule or the client script that worked.
Thanks in advance
Sruthi
Rajesh Mushke
now we will check which one is runs,
we can achieve this by using a message in business rule, so please use this option like below
if the messgae is fired business rule is working or else client script is worked, kindly let me if this helpful or not
jbjhhuhuihn
its run client side or server side for bussiness rule
Mannam Praveen
Hi sruthivarghese
Business Rule work on the sever Side.
Client scripts work on Client side(Browser Side)
Using Business Rule we can perform below operations
1.Insert 2. update. 3.Qurey 4.Delete
Using client scripts we can perform below things
1.onchange, on submit, onload
