Display values only for specific categories and fix input values otherwise
matsuo akari
Categories currently exist: Test, Software, Hardware and Network.
Category: When selecting a test, display "This is a test" in the short description.
However, when a category other than test is selected, the short description "This is a test" is deleted and the user writes an arbitrary description.
Here, when the category is selected from non-test to non-test, the description entered in the short description will not be deleted and will continue to be used.
For example, when selecting Category: Software, enter "I am a company employee" in the short description. Next, when Category: Network is selected, the value of short description will continue to be displayed as "I am a company employee" that was entered when Category: Software was selected.
To achieve this, I wrote the script below. but it didn't work. Can someone please help me? Thank you.スクリーンショット (51).png
Sonam Tiwari
@matsuo akari ,
I see what you are saying. I tested it again and saw the issue.
Figured out that oldValue is not something that we can catch until the record is saved. So I tried to find something to fetch the previous value and came across this post:
https://www.servicenow.com/community/developer-forum/onchange-client-script-previous-value/m-p/21614...
With the help of this, I could rewrite the script and it worked fine for me.
    var previousValue;
    if (g_scratchpad.previousValue == undefined) {
        previousValue = oldValue;
        previousValue = g_scratchpad.previousValue;
    if (previousValue == 'test') {
       // g_form.addInfoMessage(previousValue);
        g_form.clearValue('short_description');
    if (newValue == 'test') {
        g_form.setValue('short_description', "This is a test short description");
        g_form.setValue('short_description', g_form.getValue('short_description'));
    g_scratchpad.previousValue = newValue;
 Please test once with required changes from your end.
Hi! @Sonam Tiwari
Sorry for the late reply I tired the script you wrote and it did what I wanted.
I thank you from the bottom of my heart.
Thank you!!!
