Downloading All attachments using SNGuru solution to capturing all attachments on a task as a ZIP file ?
Liyakhat
Mega Expert
Hello All,
I am trying to download all the attachments from attachment table for incidents/request items
i have seen a solution provided by servicenow guru
https://www.servicenowguru.com/scripting/download-attachments-zip-file/
this works fine for single incident/request item and it downloads perfectly
my requirement is to download all the attachments from the attachments table,here we are passing sys_id and table name from ui action to script processor ,can we pass multiple sys_ids and loop through it to download all attachments of all incidents??
asifnoor
Hi Liyakhat,
I have provided a similar solution earlier here in the community.
Kindly refer to this link where I have tweaked the code to download all attachments as a zip file. Follow the steps given in the Accepted answer in this link and it will work for you.
https://community.servicenow.com/community?id=community_question&sys_id=e225af43db6f67844abd5583ca96...
Kindly mark my comment as a correct answer and also helpful once worked.
11 REPLIES 11
Hello asifnoor,
i see only images are downloading is it not downloading pdf,docs etc do i have to make any further changes??
Do you see pdf or docs in this line output?
gs.info("Entered into this loop"+file);
Make 1 change in the code
Replace this line
if (gr.next()){
WITH
if (gr.getRowCount() > 0){
and it will work.
hello asifnoor,
no it did not entered into the logs,only i see images png/jpg
The line is present in the while loop, so you should get that log.
Also make the above change in code which i gave in my last post and then check.
