Exporting & Importing project template with project tasks
brown9394
Hello Experts,
I need to export and import project template from DEV with tasks related to that project into QA. I cannot seem to capture all the 'project tasks' within the template while exporting so I can import the template into QA. Any ideas how this can be done?
Here's a screenshot of project template containing tasks - but when Exported, the Tasks do not get captured. I've tried XML, XLS, and CSV export. There 50 tasks, and I would hate to create them again from scratch.
JR Guieb
I just ran across this issue and thought if I exported the Project Template into XML it would capture the project template tasks as well but it didn't.
What you will have to do in order to export and import project templates with the project template tasks is do the following:
  1. Export the project template into XML
  2. In the filter navigator type project_template_task.list
  3. Filter the list to the specific project template the project template tasks belong to
  4. Export that list to XML
  5. In your instance you want to import to, you will need to first import the XML for the project template
  6. Then you will want to import the XML for the project template tasks
