Field auto population is not working for snc_external users
Aruna Sree Yela
There are 2 fields Factory Name and Factory ID. Factory ID should be auto filled with the ID of Factory selected under Factory Name. To fulfil this, I created Glide Ajax. It is working good for snc_internal users, but not for snc_external users.
As snc_internal user:
As snc_external user:
Preview record is also working and displaying the fields(for both users).
Provided Read access on the Factory Table over table level and fields level. Even though its not populating the value, its returning null.
Can anyone please help me on this issue.
Aruna
2 ACCEPTED SOLUTIONS
Hi @Aruna Sree Yela
Can you please create an ACL with roles snc_internal and snc_external as mentioned in the screenshot. Name would be your script include name.
Thanks and Regards,
Saurabh Gupta
Try and create an ACL to allow snc_external to be able to execute that script include. this should solve your issue
ACL should look like below
-Anurag
@Anurag Tripathi , @Utpal Dutta , @Saurabh Gupta
Many Thanks for the quick responses!!
There is no ACL under the Script Include
@Utpal Dutta , I tried the other way, even though I can't able to sort it.
Hi @Aruna Sree Yela
Thanks and Regards,
Saurabh Gupta
-Anurag
Ankur Bawiskar
@Aruna Sree Yela
Client callable script include cannot be directly called by snc_external role
in your client callable script include add the isPublic function along with your existing functions
isPublic: function(){
return true;
check this link
Privacy on client-callable script includes (instance security hardening)
