Filter Assigned To values using reference qualifier and script include
heathers_
Hello, I need to filter the Assigned To values based on value of another field. If the condition is not met, I need to display the full list of group members for that specific assignment group. Below is my attempt thus far... any insight or ideas?
Condition: If "u_hr_confidential" = Yes, only display the users with role "sn_hr_core.u_hr_confidential" from assignment_group in assigned_to.
Else, display all users in assignment group.
Reference Qualifier on Assigned To
javascript: new sn_hr_core.HrCaseAjaxUtils().getConfidential(current.u_hr_confidential);
Script Include
var HrCaseAjaxUtils = Class.create();
HrCaseAjaxUtils.prototype = {
    initialize: function() {
    getConfidential: function(field) {
        var confidential = current.u_hr_confidential;
        if (field == 'Yes') {
			gs.info("HRSD1: " + role);
			gs.info("HRSD2: " + confidential);
            var gr = new GlideRecord('sys_user_grmember');
            gr.addEncodedQuery('user.roles=sn_hr_core.u_hr_confidential');
            var arr = [];
            while (gr.next()) {
                arr.push(gr.sys_id.toString());
            return 'sys_idIN' + arr.toString();
heathers_
Using a combination of all recommendations, I have resolved the issue while keeping the script include Client Callable.
    initialize: function() {},
    getConfidential: function(u_hr_confidential) {
        gs.info("HRSD1: " + u_hr_confidential);
        if (u_hr_confidential == 'Yes') {
            gs.info("HRSD2: " + u_hr_confidential);
            var arr = [];
			gr.addQuery('group',current.assignment_group);
            while (gr.next()) {
                arr.push(gr.user.toString());
            return 'sys_idIN' + arr;
    type: 'HrCaseAjaxUtils'
Appanna M
Hello @heathers_ ,
Please correct the below line.
javascript: new sn_hr_core.HrCaseAjaxUtils().getConfidential(current.variables.u_hr_confidential);
Same type of requirement please follow the Ref URL: https://www.servicenow.com/community/developer-forum/advanced-reference-qualifier-in-servicenow-base...
Please Mark My Answer as Helpful and Accept as Solution, if you find this article helpful or resolves your issue.
@Appanna M Thank you for your response. These are not variables. I am creating this directly on the sn_hr_core_case table.
You script include doesnt need to be client
There are several correction you need to make
            gr.addQuery('group',current.assignment_group); // You should query the assignment group as well
            var arr = [];
            while (gr.next()) {
                arr.push(gr.getValue('user')); // You should pass the user sysid here
I don't need to make this client callable?
Adjusting based on your recommendations and assigned_to is displaying the complete list of group members. Still not seeing the few members with the queried role.
