Fix Script Role contains Roles, problem in views.
juancarrion
Hello Community,
I have a problem in my current development that I couldn't crack.
1. I want to find all the users which has the view_changer role.
2. Problem is that view_changer role is contain in several roles, groups,etc.
Bottom line how can I find all the roles and group that contains view_changer role?
because thinking itil has the view_changer and admin has itil so at the end both admin and itil have the view_changer is there any easy way to do this on ServiceNow?
2 ACCEPTED SOLUTIONS
JenniferRah
I just ran this and it seemed to work:
gr.addActiveQuery();
var count = 0;
var x = gr.getRowCount();
var curuser = gs.getUser();
while(gr.next()){
	var user = curuser.getUserByID(gr.user_name);
	if(user.hasRole('view_changer')){
		gs.print("** " + gr.name + " has role");
		count++;
gs.print("** Found " + count + " users out of " + x + " with role.");
jcmings
Find all roles that contain view_changer
Navigate to sys_user_role_contains.list and search for the role view_change
Find all groups that contain view_changer
Navigate to sys_group_has_role.list and search for the role view_change OR whatever roles you identified that contain the role
Find all users that have the view_change role
Navigate to sys_user_has_role.list and search for the role view_change OR whatever roles you identified that contain the role
Ankur Bawiskar
@juancarrion
share the script you are using
