ā07-01-2020 01:55 AM
Building a flow in flow designer, and the last steps are to
- create a knowledge article using the information contained in the problem_task record
- confirm Knowledge article exists
- copy the attachment from the problem_task record to this newly created knowledge article
Step 1 and 2 works and I can see the Knowledge article but step 3 does not work as expected.
Copy attachment step keeps on giving this error
Error: The Record type problem_task does not match with Attachment table type. (sys_script_include.5430bdf89313130079b5925cf67ffb04.script; line 30)
even though i can see all the correct values are being returned
Any guidance or help on what I am doing wrong will be appreciated.
Personal Developer Instance
ā07-21-2020 04:55 AM
Thanks for sharing the image.
I believe this question was answered previously.
if you think there is any response that helps you please mark that helpful or accepted so that this thread can be closed.
ā07-03-2020 05:30 AM
yes before insert BR should work
not sure from flow
ā07-13-2020 08:17 AM
Can you please help knowing whether you were able to copy all attachments to target record?
please share screenshot
ā07-21-2020 04:40 AM
ā10-20-2025 03:22 AM
Stupidly I thought that the Action would have taken care of all the checking and looping etc, how lazy of SN š¤¦āāļø Thanks for the screenshot it helped šš»
