07-01-2020 01:55 AM
Building a flow in flow designer, and the last steps are to
- create a knowledge article using the information contained in the problem_task record
- confirm Knowledge article exists
- copy the attachment from the problem_task record to this newly created knowledge article
Step 1 and 2 works and I can see the Knowledge article but step 3 does not work as expected.
Copy attachment step keeps on giving this error
Error: The Record type problem_task does not match with Attachment table type. (sys_script_include.5430bdf89313130079b5925cf67ffb04.script; line 30)
even though i can see all the correct values are being returned
Any guidance or help on what I am doing wrong will be appreciated.
Personal Developer Instance
07-21-2020 04:55 AM
Thanks for sharing the image.
I believe this question was answered previously.
if you think there is any response that helps you please mark that helpful or accepted so that this thread can be closed.
09-09-2024 05:52 AM
¿como vas a poner un vinculo en una imagen?
sos de los que mandan el CBU en una foto? o tus viejos son primos?
06-09-2023 04:19 PM
This helped me. Thank you Ankur.
