Flow Designer - REST Step | how to pass a token from script step to the REST Step.
Meloper
Hi, due to different requirements on the body I need to query the token in a script step before the rest step.
The token I get is currently still in the log.
Now I have problems to pass the token to the rest step.
The token uses a connection alias and in my opinion expects the token in the oauth_credential table.
For example, if I request the token manually via the UI action ‘get Oauth Token’. The token is stored in the oauth_credential table and the REST step then accesses this token.
How do I do this in a script step for the REST step?
How do I transfer the token?
@Meloper
Hope you are doing good.
Hi its was helpful 🙂 and i marked it already as this
