Flow Designer Run-As Problem
jlaps
I am using Flow Designer to ingest an emailed report. When I "TEST" this in Flow Designer, it works with no problem. The problem I am having is when the email is grabbed, even though I have the RUN AS set to SYSTEM USER, the flow instance is getting blocked when trying to get the EMAIL ATTACHMENT and the flow stops. The process is running on a GUEST account for reasons unknown (perhaps because the email sender is an email address that has no account?), even though I have it set for SYSTEM USER. What am I doing wrong?
jlaps
Why is RUN AS ignored on flows using incoming email trigger?
